Hey guys
I recently picked up 4 ip2m-841b cameras. 3 of the 4 work great.
One of them seems to be exhibiting a static / crackling noise. Its hard to describe.
This is NOT the sound it makes when it switches between night vision and normal which is a audible click.
I have tried to update to the latest firmware (IP2M-841_IPM-721_V2.420.AC00.17.R.20170322) and it has not fixed this issue.
Has anyone else noticed this? Aside from this issue I am extremely satisfied with these cameras.
Thank you.
ip2m-841b crackling noise?
Re: ip2m-841b crackling noise?
Hello I currently just purchased 3 of the same cameras you have and no, no strange sounds as you describe above. Everything working great. Unfortunately you might have a bad one out of the bunch you bought and setup.
