Amcrestview
bobgallahan
Amcrestview
Postby bobgallahan » Tue Jan 15, 2019 6:51 am
For the last two days when trying to view my NVR through https://www.amcrestview.com/, I get "This Site Is Not Secure". I get that on IE and Firefox. Has the SSL certificate expired or something else is wrong. I'm getting this from my home pc and work pc. Any words of advice? Thanks
kylerk
Re: Amcrestview
Postby kylerk » Tue Jan 15, 2019 11:17 am
I gave up on Firefox long ago due to issues with getting Amcrest plugins not working correctly - but I have experienced the exact same behavior with IE on my Windows7 desktop for the past two days that you have. However, on the 13th and 14th I was able to get the app to work by choosing to "Continue to this website (not Recommended)".
This morning (1/15/19) I did not even get that far - it would not connect, and I also had no luck trying by using Amcrest View Pro from my iPad.
I just tried again a few minutes ago and I am back to where I was on the 13th & 14th being able to access www.amcrestview.com by choosing to ignore the error, and now I am able to use View Pro on my iPad.
I hope they get their certificate renewed soon - I rely on using these applications and would feel more comfortable if they were working correctly.
Medved
Re: Amcrestview
Postby Medved » Wed Jan 16, 2019 7:04 am
Is there any information on when amcrestview.com certificates will be renewed. I can not access my web cams via the web.
bobgallahan
Re: Amcrestview
Postby bobgallahan » Wed Jan 16, 2019 7:41 am
I imported my Amcrestview account settings into the Amcrest surveillance pro app on my windows 10 pc, but the live video is real laggy. But that may just be my bandwith isn't verygood.
decaturbob
Re: Amcrestview
Postby decaturbob » Wed Jan 16, 2019 8:39 am
I can't even get the plugin to load (running firefox) where every time I access amcrestview it tells me to download and install
bobgallahan
Re: Amcrestview
Postby bobgallahan » Thu Jan 17, 2019 7:41 am
My issue has been solved today, Amcrestview.com is back to normal I submitted a support ticket two days ago. I guess they updated the SSL Certificate.
Amcrest's reply to my ticket below:
Kwing L. (Amcrest)
Jan 16, 10:43 AM CST
I apologize for the inconvenience this has caused for you, we are currently working on updating those certificates for amcrestview.com.
bobgallahan
Re: Amcrestview
Postby bobgallahan » Thu Jan 17, 2019 8:54 am
The only Firefox fix that has worked for me is to download and install Firefox version 49.0.1 32bit.
The 64 bit would not work.
https://ftp.mozilla.org/pub/firefox/releases/49.0.1/
kylerk
Re: Amcrestview
Postby kylerk » Thu Jan 17, 2019 10:08 am
This morning everything is back to normal for me too - Thanks Amcrest.
decaturbob, You have two choices:
- Do as bobgallahan did and move to the 32-bit version of Firefox.
- Or you can do what I did - I use Internet Explorer 11 exclusively for my Amcrest activities, and I still have my 64-bit Firefox that I use for all of my other internet activities.
Medved
Re: Amcrestview
Postby Medved » Fri Jan 18, 2019 10:47 am
Working again here too! Thanks.
Return to “General Discussion”
Who is online
Users browsing this forum: No registered users and 1 guest
