Problems setting up PC-NVR
hoogw
Postby hoogw » Fri Jul 12, 2019 2:38 pm
as of 2019 July, this software still NOT fix this bug. I have same admin locked offline when add pc-nvr.
This software NOT update since 2016!!!!!!!!!
Those bugs never fixed since.
The work around is,
Uninstall everything !!!!
Restart windows!!!!!!
manually Delete original folder at c:/program (x86)/Amcrest .... !!!!!!!!
above every steps is very important, otherwise, you will failed again.
now re-install surveilance pro again,
finish
open, prompt up , ask for new password,
use 'admin' !!!!!!!!!!!!!!!!!!! (not other password) this is the reason cause later locked (offine) issue.
Now it is working
TahirB
Re: Problems setting up PC-NVR
Postby TahirB » Fri Jul 12, 2019 3:48 pm
Hey hoogw, we are currently working on a new version of Surveillance Pro to release later this year, you can find the beta version here: https://amcrest.com/forum/amcrest-surve ... 12605.html
We have made a few changes to make PC-NVR more user friendly, please check it out and let us know how it works for you and leave any feedback you have.
Return to “Amcrest Surveillance Pro”
Who is online
Users browsing this forum: No registered users and 1 guest
