Dazed and confused senior citizen
beaner2u
Post by beaner2u »
I have a NV4108E-A2 with seven IP cameras hooked straight to the NVR and my home network. The cameras and NVR work great.
I have a Windows 11 pc, I7 eight core, gobs of memory also hooked straight to the same home network.
I installed Amcrest Surveillance Pro on my PC and it cannot find my cameras.
If I go to the main menu of my NVR, and then click on cameras, the IP address's are way out of line with my systems basic IP address, all except one, a WIFI camera.
I also installed and ran the IP Config Tool, it only found the WIFI camera.
One thing I do notice on the CAMERA screen of the NVR, the ports are all different.
Any help greatly appreciated, Roger
Pogo
Re: Dazed and confused senior citizen
Post by Pogo »
The cameras on the NVR will not be on your normal network, but rather on a subnet generated by the NVRs dhcp server. Individual camera access will be accomplished via the NVR itself, not from your network. Adding the NVR to ASP should assist in accomplishing this.
