ASP: The APP doesn't look right on a 4k monitor.
BobTheDroid
The APP doesn't look right on a 4k monitor. Text labels are cut off. Buttons are tiny as ants. If you're selling 4k cameras, at least test your software on a 4k monitor!!!
Re: ASP: The APP doesn't look right on a 4k monitor.
I have a 4K (3840x2400) laptop, usually connected to a 4K monitor and can run ASP visually on either just fine.
The workaround to achieve this is to right click the ASP icon, select: Properties / Compatibility / Change High DPI Settings / Check the box "Override high DPI scaling behavior" / select scaling performed by SYSTEM (or SYSTEM enhanced) / OK.
Note that this change modifies only the app's default scaling and not Windows in general. See this post for further info...
https://amcrest.com/forum/amcrest-surve ... tml#p41828
