Amcrest Surveillance Pro 2.0 Beta
mromamcrest
Postby mromamcrest » Thu Jun 27, 2019 6:48 pm
Amcrest Users,
We welcome all our customers to our Software Beta testing. This beta is for Amcrest Surveillance Pro 2.0 (code name SmartPSS) which will also be referred to as ASP 2.0 interchangeably. Below are details of how to participate, we will list any new features and known bugs with the new Test ASP. Let us know your feedback and if you discover any new bugs!
Caution :!:
This Test Software is only for Windows.
Software changes
Only for Windows. Mac version is still in the works for future development.
32-bit only. Upon release 32-bit and 64-bit versions are planned to be included and will function exactly the same except the 64-bit version will be more optimized for 64-bit PCs.
Software Beta
For Windows ONLY
https://www.dropbox.com/s/32v3g6oaup2j4d5/DH_SMARTPSS-Win32_ChnEng_IS_V2.002.0000008.0.R.190609.exe?dl=0
If you have any issues with the Beta Software and or need to go back to the Previous Version, please use the below latest ASP software
Previous ASP version
For Windows ONLY
https://amcrest-files.s3.amazonaws.com/Amcrest+Surveillance+Pro+Setup+V1.14.1.R.20161018.exe
Please leave any feedback, suggestions, or bugs you run into on this forum post. With your help, we hope to be able to address all bugs faster and be able to release the new ASP software sooner.
Thank you,
James S.
JVRx77
Re: Amcrest Surveillance Pro 2.0 Beta
Postby JVRx77 » Sun Jun 30, 2019 10:27 am
Windows 10 Pro Insider Preview V. 1903 OS Build 18922.1000
P2P does not function, can add cameras & NVRs but not connect to them.
Playback; can only view one video stream at a time, can select multiple cameras/streams but only the first/top of list is viewable.
James.S
Postby James.S » Tue Jul 23, 2019 9:36 am
Wanted to confirm with you and let you know we greatly appreciate you help in testing the new Beta software. Please let me know if you find anything else
If you have any more questions or concerns about this product or other Amcrest products, please reach out to us at [email protected].
- James.S
RB1
Postby RB1 » Tue Jul 23, 2019 9:45 am
Motion Detection:
1) does not show (as yellow sections) on playback bars
2) only one bar will show, not multiple cams
PC-NVR:
1) randomly turns itself off when selected to be on or on when selected to be off
Windows 10 / IV4M-1026 cams
RB1
When will you be uploading a newer beta version?
James.S
Postby James.S » Tue Jul 23, 2019 9:54 am
I am hoping to be posting another one soon, Unfortunately, this heavily relies on the engineering team.
Thank you for the feedback as well I have sent this off to them.
- James.S
SchwannyT
Postby SchwannyT » Wed Jul 24, 2019 4:52 pm
Does this beta also include a new version of the PC-NVR software, or is it the same as the 1.14 version? Will I need to install that as well for recording/playback?
spleen911
Postby spleen911 » Mon Aug 12, 2019 3:12 pm
The option to sync time with configured devices has a bug (exists in 1.14.1 too). It does not consider time zone so each day when it syncs my 5 NVRs, the time zone on the NVR is changed from GMT-5 to GMT-4. I'm running ASP on Windows 10 Pro in GMT-5+DST. All the NVRs are set to GMT-5+DST, but each time ASP updates time on the NVRs it changes them to GMT-4. From a "math time" perspective GMT-5+DST is -4 hours from GMT during DST, but that is not the same as GMT-4: the offset changes ... not the time zone. If I change my PC to GMT-4+DST ... ASP changes the NVRs to GMT-3 when it updates time.
James.S
Postby James.S » Tue Aug 13, 2019 12:07 pm
Sorry for late reply yes it does. not if you have an SD card or HDD in your device.
Thank you very much for this awesome information, I have sent this over to our R&D team to look into for the next update.
- James.S
Return to “Amcrest Surveillance Pro”
Who is online
Users browsing this forum: No registered users and 1 guest
