ASH 26 siren not working
So I am not sure if this is an issue with the camera or if this is a software issue with Amcrest or not. I mean my Ad410 siren works so I would think if it was a Software issue and contact with the Servers that neither of them would work. So then I will admit something that did worry me a little when Installed the MSD is the placement and function of access. With my snow this winter I wonder if maybe the camera has water damage and why it won't turn on the siren? I tested with my Wifi and I tested on my Cell wifi and both fail to start the siren. I can still access the light on the app.
Anyway anyone other then me have an issue with turning on the Ash26 siren?
robobro
Re: ASH 26 siren not working
Post by robobro »
I'm having the same issue.
when i try to activate the sire in the app it give me a warning, then a message that says "Talking Now"
consequently, when i try to use the talk function is is also not working.
firmware is up to date and everything else seems to be fine.
robobro
Post by robobro »
While we're at it.. .this is still an issue, even with the brand new ash26 i installed last week the siren does not work on motion detection or manual activation.
I can't say. I would if I were you start with 2 things. 1 reboot the camera. and try again. If that don't work reinstall the Firmware and test again. I know that I had some issues with it some time ago. I mean it has been over a year and that isn't an issue now. I can make it go off with no issues. Now I will admit at times I have to reboot the camera when I try to make some dog leave the area where I have my camera installed. However once I reboot the Siren works without fail today. So not sure why you are having issues. As I said first off I would reboot the camera.
