I have two of these and one is sending me motion detection alerts every few minutes--likely due to snow. I have another mounted on the other side of the house that's giving me not issues. I've reduced the motion sensitivity down to level 1 which may have helped a bit. I turned off human detection since it had been sending me false alerts with that heading.
I turned an outdoor light off and that does not seem to have any effect on the illumination of the snow. Thoughts?
Amcrest 1080p outdoor bullet security camera (ASH22-W)
Re: Amcrest 1080p outdoor bullet security camera (ASH22-W)
If you have some lighting on snow cam side, you could try turning off NightVision (IR light), and see what happens. The IR light may be reflecting off snow.
