Please login first screen in IE or IE mode for chrome
hi. i have a big problem with 4108 nvr. when i am trying to connect nvr with IE, i get this message - please login first. when i use chrome or firefox, everything is good exept one moment - i can't enlarge image or speed up video and also there is no backup option. i think problem is webplugin. the latest version doesn't work properly with IE. can anybody give me older version of webplugin?
- IE
- Screenshot_614.png (21.26 KiB) Viewed 5412 times
- IE
- Screenshot_615.png (36.61 KiB) Viewed 5412 times
- CHROME
- Screenshot_616.png (33.64 KiB) Viewed 5412 times
Re: Please login first screen in IE or IE mode for chrome
I use it and no issues with playback. I would restart your computer also maybe look into using ASP for playback. In the past had some issues with repeated plug in installs because my cameras require different one so I just used ASP Amcrest Surveillance Pro. Because it was problematic trying at access both cameras at same time.
can you send me your versions of webplugin?
i found out the problem. i connected with http port instead of tcp port. everything works
