WiFi vs Hard-wired Network Connection To NVR
kjward
Post by kjward »
i am currently running view pro on a wifi android tablet with no lag in any of the camera feeds; however, when i use surveillance pro on a hard-wired laptop on the same home network, the camera feeds are slow to refresh and time-choppy/jumping.
any advice?
Re: WiFi vs Hard-wired Network Connection To NVR
I am going to guess that there is either a Memory, CPU or wired connection issue on the laptop.
At times it might be that the camera is the issue. If you look at cameras Encoding and if it is Setup for H265 move that back to H.264h and see if the issue goes away. Another issue keep in mind is that a Computer has many things that it can be doing in the background. IF your computer is trying to do a Microsoft Update issues can come up.
Outside of that there are many things that could be at play. When you click on the top meter what is the CPU and Memory running at?
What type of computer/CPU/Memory are you using?
