I purchased a few Amcrest DVRs, and want to be able to see the DVRs and their camerasw, on my iphone, from remote location.
IS there any app that is available that lets us do this?
Thank you
How to view Amcrest DVR from remote on iphone
Re: How to view Amcrest DVR from remote on iphone
So in the Amcrest View Pro App there is a feature already built into the DVR/NVR's and the app.
You will want to make sure that your Recorder has access to the internet. (My Router is setup to Block all new connections) So I have to give all new connections access.
Second you will want to remove the Recorder from your app now, then Press the + to add it back, then press the DVR/NVR and choose P2P, Then using the Phones camera scan the SN of the Device most of them are on the Top front corner (Right Side) If yours no longer has the sticker you can log into the Recorders WebUI or even get it from the Recorders GUI,
GUI, Right click Main Menu, Network, P2P, in there you will have 2 QR COdes, One for DL of the App and second is the SN for the Recorder. also at the same time you can Check to see if your P2P is connected. It should say ONLINE. IF it isn't Enabled, Enable it...
Or you can enter the SN manually, GUI, Right click Main Menu, Maintain, System Info and it will have the SN in there you will need to enter it all.
