Waterproof connector for outdoor IP camera
jakthree
Post by jakthree »
What is the part number for the 4-piece waterproof connector that come with the outdoor IP camera and where can I buy it?
Thank you,
Re: Waterproof connector for outdoor IP camera
don't know really I just know that I have bought mine from this person on Ebay.. So I don't know where to find it out side of Ebay. I am sure there are others but nothing less https://www.ebay.com/itm/184569201106?h ... SwpVxfzUc7
jakthree
Post by jakthree »
Revo2Maxx,
Thank you for the reply. Now I have more confidence in buying from that person.
jakthree
Post by jakthree »
I bought four and received two different types. one type has a square inside and will slide over a RJ45. The other has a round hole that has to be put on before installing the RJ45 connector. Luckily I make my own cables so I was able to use the one with the round hole. Both styles of the shells are equally good at keeping weather out. I always use di-electric grease on the RJ45 to prevent corrosion.
