Vera Smart Home Controller
davidp
Post by davidp »
Has anyone had any luck getting this to work with Vera Smart Home Controller? I'm have a Vera Edge with UI7 and am unable to get it to connect. If anyone can post the specific setting that would be great.
medic61
Re: Vera Smart Home Controller
Post by medic61 »
You didn't post what model of camera. I have a IP3M-954E, in Blue Iris I had to choose the Dahua Main Stream RTSP. Hope this helps.
mccrizzle
Post by mccrizzle »
Yes without issue. I have a Vera Edge and Amcrest IP2M-841 camera.
Add Camera -> generic IP cam -> go through the wizard until it auto searches to find the camera. It didn't find mine, so I clicked "manual install". Select the IP of the camera. And then fill in the fields below. You need to know the login info for the camera. And this is the URL that you need to enter: cgi-bin/snapshot.cgi?
MettyFt
Post by MettyFt »
I think this Smart Home Controller can help a lot in housekeeping! thanks for letting us to know!
