Switch IP3M-941B from Wired to Wireless?
hawkeye62
Post by hawkeye62 »
I am doing some experimenting with one of my IP3M-941 cameras. I have it set up with an ethernet connection to my home network. It works perfectly. Now, I want to switch it to a wireless connection to my home network. I haven't been able to find instructions on how to make that switch. Any advice will be very much appreciated.
Regards, Jim
longedge
Re: Switch IP3M-941B from Wired to Wireless?
Post by longedge »
If you login to your camera web user interface and go to the network section then select WiFi and enable it, your camera should search and then display any SSID's that it can 'see'. Select your own and complete the user/password details and connect. Then go to the Network TCP/IP section and change the camera from wired to wifi default. Don't forget to save as you go. Disconnect the ethernet cable and the camera should now be connected. I would also do a reboot to make sure that things are working.
My AMCREST Cameras:-
hawkeye62
Post by hawkeye62 »
Thanks longedge! That worked for me.
Regards, Jim
