Stream out
chadstone
Stream out
Post by chadstone »
Hello. I just implemented my IP4m-1053EW to capture a new building being built for my hospital. Im only seeing the viewer is via the plugin, or iOS app, so my question is, is there a way to broadcast the live stream over an RTSP or UDP protocol so that I can implement it into my intranet page for my organization? Thank you
Re: Stream out
Hello and welcome to the Forum
While I am not 100% sure with your camera but here is some info about RTSP
https://support.amcrest.com/hc/en-us/ar ... -Streaming
jack7
Re: Stream out
Post by jack7 »
chadstone wrote: Wed Apr 08, 2020 7:43 am Hello. I just implemented my IP4m-1053EW to capture a new building being built for my hospital. Im only seeing the viewer is via the plugin, or iOS app, so my question is, is there a way to broadcast the live stream over an RTSP or UDP protocol so that I can implement it into my intranet page for my organization? Thank you
You could try this:
https://support.amcrest.com/hc/en-us/ar ... -Multicast
