RTSP (VLC) and ffmpeg syntax
Re: RTSP (VLC) and ffmpeg syntax
I mean this one does bring back some data or my AI camera not sure if it is the info your looking for but just use your cameras IP in place of mine
http://10.0.0.160/cgi-bin/devVideoAnaly ... &channel=1
GaryOkie
Post by GaryOkie »
I recommend searching for and downloading the Amcrest HTTP API doc to learn what all the "Get" device capabilities commands are. There are a lot.
I find this command to be the most useful to list the current active configurations...
<ip>/cgi-bin/configManager.cgi?action=getConfig&name=All
YetAnotherDave
Post by YetAnotherDave »
Now working on Home Assistant with the Dahua HACS integration https://github.com/rroller/dahua
I appreciate your quick responses. Thanks again!
YetAnotherDave
GaryOkie wrote: Wed Oct 20, 2021 2:00 pm I recommend searching for and downloading the Amcrest HTTP API doc to learn what all the "Get" device capabilities commands are. There are a lot.
Will do.. that returns a LOT of data. very nice.
davidnpgtech
Post by davidnpgtech »
An alternative that I used instead of FFServer was Red5 Pro. On Ubuntu, I used this line:
Code: Select all
ffmpeg -f pulse -i default -f video4linux2 -thread_queue_size 64 -framerate 25 -video_size 640x480 -i /dev/video0 -pix_fmt yuv420p -bsf:v h264_mp4toannexb -profile:v baseline -level:v 3.2 -c:v libx264 -x264-params keyint=120:scenecut=0 -c:a aac -b:a 128k -ar 44100 -f rtsp -muxdelay 0.1 rtsp://localhost:8554/live/paul
