Q-Cam Camera's on a Amcrest NVR
jacol1
Post by jacol1 »
Good Morning, I have a Q-Cam system that is 1.5 years old and working fine, the customer needed additional cameras and wanted 1 nvr instead of 2 so I purchased a NV4432E-HS and 7 additional cameras, which work fine on the 16 port POE/32 port NVR and the Q-Cam cameras(IP3M-954E) are found by the new NVR but I cannot add them to where they will connect, all are 3 mp camera's on the NVR, does anyone know what settings I would use to set the Q-Cam's up on the new NVR. Thank you
Melvin
Re: Q-Cam Camera's on a Amcrest NVR
Post by Melvin »
Hello jacol1 ,
The Qcam comes from a different manufacturer and is not fully compatible with Amcrest NVR's. If you have a POE switch, connect the QCam to that and then connect the swicth to the same router that the Amcrest NVR is connected to. This way you can add the Cameras as an ONVIF device.
