pin hole camera?
padmaster
pin hole camera?
Post by padmaster »
Are there any wireless pin hole cameras that are compatible with the NV4108E-HS NVR?
Re: pin hole camera?
Amcrest Pin Hole camera? I don't think they have one. I personally wasn't able to find one on the sales pages anyway..
With that said I do have some pin Hole cameras and there is some info you might want to know about (Older Tech). 90% of the ones I know about use different type of IR 940nm where the normal IR is 850. That is to help keep the red out of sight (Can still be seen by other cameras looking at the IR) just can't be seen by the naked eye.
Next there are some cameras out there that are for use with there own app. You want to look for one that says it will work with ONVIF. Or you could find one like my older CVBS camera that I Connect to my DVR and can use my NVR to access my DVR on that cameras channel. If you had a DVR with open channel that might be an option as well..
Keep in mind a quality hidden camera can be costly. I wouldn't buy one that claims it is over 2mp and even one at that size might be questionable. My old CVBS one is 480TVL and my ONVIF one is only 1mp.
I mean there are many advances in Tech and might have better cameras today. I just have not seen any as I am not in the market for one.
