Here are specs on my camera.
Software Version2.420.AC00.26.R, build : 2016-08-31
WEB Version3.2.1.329792
ONVIF Version2.4.2
S/NAMC0196HFJ9C54D70D
I have gone into Storage -> Record Control and made sure that "Disk Full" is selected as overwrite and it always has been. My SD card is now full and it will not record anything else. What can I do to fix this?? I really don't want to format my SD card...
Once SD Card full its stopped recording
Re: Once SD Card full its stopped recording
Hello phelix,
Please try power recycling the camera. Also under system > Auto maintain > Auto delete old files, set a value and reboot the camera using the manual reboot option and see if it works.
