NV4108 Firmware Update?
I notice there is a new updated firmware download available for the NV4108. Has anyone tried it? Apparently no notes available, but since I am experiencing no real problems with mine, don't want to rock the boat if the update doesn't add anything of real value.
Re: NV4108 Firmware Update?
Where did you see a new firmware? The latest one I see is from 3/30/16, though my NV4108 shows a build date of 4/26/16. I wish they would update some of the small issues with the software. These cameras are great, but the software side holds them back somewhat.
the_buzz_man
the_buzz_man
I guess it wasn't really new after all, but prior to the last few days, only the NV4108E had a firmware download available. So when I suddenly saw an update was available for the 4108, I posted. Now, I see that both NV4108E and NV4108 downloads both are older than your build date, which is the same date as my NVR has. Sorry, false alarm...unless the earlier build dates will fix something the newer build date broke? Who knows.
