From my IP3M-956E, I can get a 3MP snapshot with this request: "http://[cameraIP]/cgi-bin/snapshot.cgi."
Why is it that I can get only a 3MP snapshot with the same request "http://[cameraIP]/cgi-bin/snapshot.cgi" from my IP5M-1173E?
What's troubling is that the 3MP snapshot from the 5MP camera seems to a 2304x1296 cropped version of the full resolution 2592x1944 image - specifically the upper left portion!
What do I have to do to get a full 5MP 2592x1944 snapshot from the IP5M-1173E?
Thanks!
Need full resolution snapshot
Re: Need full resolution snapshot
I am going to guess and this is only a guess as my mind isn't as sharp as it once was.
Some Higher Resolution cameras don't take a FULL 5mp snapshot. There should be something in the Manual or Spec Sheet that states what the Max Res is. I don't remember what camera
I would also to be safe look under your Snapshot area and see what you have it set at for taking them. It might be only a Setting that needs to be changed in settings. I know you can setup different snap Res...
Also looking at my Amcrest Cameras Config just now I see that when I change from different Recording rates it automatic changes the Snapshot value. It might also have something to do with the Value you pick for quality as well?
However about Cropped. I remember seeing something somewhere that my 5mp TVI camera has a Different Res then a 3mp tvi and talked about one is wide 3mp and 5mp is more like a 4:3 where the 3mp is 16:9 so I wonder if it isn't the same for your setup. Sorry my cameras are from another manufacture so it is hard to say. I know that I am using my 5mp in 3mp mode to get the wider picture.
Hope something was found helpful
James
James
No luck changing the snapshot resolution to 5MP with various configuration changes.
Currently running with firmware "ver 2.460.AC00.0.R" dated 10/23/2017.
Does anyone know if the current version of "ver 2.460.AC01.0.R" dated 06/26/2018 would take care of the reduced snapshot resolution problem described?
Strange I just looked in the Manual and it states that the Snapshot size is set by Recording Resolution settings by default?
"Image Size: This dropdown box shows the image size. By default, the screenshot size
is the same size as the video feed’s resolution."
I wonder if your Recording the Main or the Sub stream and this is why.
Also looking under most 5mp Resolution status it says in General 5mp cameras are 4:3 So is normal 3mp lol so mine must be just below that because it does come out 16:9 but might be 2mp because it is a 16:10
James
James
