Max SD Card Size
cwalins
Max SD Card Size
Post by cwalins »
What is the largest micro SD card, in MB, that can be used with a IP2M-841?
amcresthell
Re: Max SD Card Size
Post by amcresthell »
Their specs say it's 64GB, but mine seems to use a 128GB card just fine and fill the whole thing up when set to continuous recording. On an 8Mbps stream, that's about 3 days worth.
FTP
Post by FTP »
Hi amcresthell,
amcresthell wrote:Their specs say it's 64GB, but mine seems to use a 128GB card just fine and fill the whole thing up when set to continuous recording. On an 8Mbps stream, that's about 3 days worth.
Can you confirm your card manufacturer, model and specs?
I try to do a small survey of cases where a 128Gb card works fine in a IP2M-841 camera...
https://amcrest.com/forum/technical-dis ... tml#p11190
Thanks! :)
