IP8M-T2499E physically hard Factory reset Possible?
JonBellagio
Post by JonBellagio »
Does anything know of a way to Physically Hard Reset a IP8M-T2499E, the IP8M-T2499EW has a switch but the IP8M-T2499E doesn't appear to have one. and the internals appear very similar.
I fat fingered a new password entry and was locked out of the web interface.
I tried removing all the wire connectors internally overnight hoping it might reset, no luck
Re: IP8M-T2499E physically hard Factory reset Possible?
Hello and Welcome to the Forum....
You will need a Phillips Head screwdriver and take the camera apart like your going to put in the SD card... Then you will get to the Reset button on the motherboard and THen you would while powered up Press and HOld it for 30 seconds until the camera resets... Then it will be back to factory where you would have to use admin admin for pass and user name
JonBellagio
The IP8M-T2499EW has a reset button, and the motherboard pictures look identical to the IP8M-T2499E but the reset switch isn't present on the IP8M-T2499E its a black transistor. Support is having me RMA this camera. I was hoping I could short a Pin on the motherboard to reset it.
Wow there is a Flaw I didn't know about.. Interesting Thanks for the update to your post... E and EW my understanding was color was only difference but I guess I was mistaken.. Now I must find one of these to play with lol
pscarbor
Post by pscarbor »
I have a 2499 EW - same issue, no reset button. This is my second: The first (my third Amcrest camera) was easy to set up but this one WILL NOT let me change its IP address, and its on the wrong subnet, 192.168.1.108 whereas my network is 192.168.0.xxx. I tried the cell phone app, IP Config and View Pro on my PC and the net interface. No nada, no way Jose!
pscarbor
Post by pscarbor »
Ok, boxed the camera up, back to Amazon and they'll send a replacement. Pardon me if this is off topic but if anyone here could give me some setup tips I'd be eternally grateful. Here's what happened:
First camera: Opened IP Config app on my PC, it found the camera immediately. I logged in, changed the password and IP address, and was done.
Second camera: Opened IP Config app on my PC, it also found the new camera - BUT would not connect to it. So, I tried View Pro on my PC. Again, found the camera, would not connect to it. Tried Google Chrome, no dice, nothing. Tried View Pro on my phone, entered the serial number. Camera connected and displayed a picture but when I tried to change the IP address to the correct subnet there was no option to do that, only 'Static' and 'Dynamic' address selection. Here's where I went into the woods: I (foolishly!) selected 'static' and that's all she wrote. Camera will not connect no way no how, and there is no way to reset it, hardware or otherwise.
I suspect I got a bum camera, but who knows, maybe I just got lucky with the first one. I called support, no answer, will try them again tomorrow.
Any suggestions would be greatly appreciated!
So yeah next time best thing to do is setup a Second IP in your Computer to be on the same Range as the camera.. Because I deal with a lot of cameras that are setup by factory as Static in the same range as your post I have as one of my IPs 192.168.1.119 on this computer another one that I use to access loads of cameras is my 109 IP and all my ranges are added with .109 on this one they are .119..
So I have on this computer 5 IP's setup in my Networking.. I have only 1 Gateway and one Subnet...
So my main IP is 10.0.0.119, yet I have 10.1.23.119, 192.168.1.119, 192.168.0.119 and a couple more for this computer but my other one has like 10.1.1.109, 10.0.1.109 and others that also are same range as the ones already listed just keep the last IP number like for computers so I know what computer made what and when looking though logs..
So my main IP as I was saying was 10.0.0.xxx and yet when I connect a camera that has this other IP that your talking about 192.168.1.108 because I have that ip in my list of Ip ranges I can make a connection and change the IP.. I have a few different post in Amcrest that covers this issue on some cameras that I have bought in the past or that has a Stuck Static IP from the normal IP that the camera was sold under however today most cameras are setup for DHCP..
One of the biggest things I have seen happen is someone will buy a POE camera that has been connected to a POE NVR that changed things in the camera, Then the user keeping it Static they change the IP in a Range for the computer side of the network and they think they bricked the camera because they can't connect to it because they forgot to make adjustments past just the IP like the Gateway is wrong, with a bad Gateway one won't be able to make a connection to a camera.. DNS, don't matter much past the Internet part of things, Sometimes it is easy to make a mistake that isn't easy to cure without a Reset button...
So to answer more on your setup...
First thing I would do is look at my Router table to see what IP's are currently in use,
Then connect the Camera to the Network, After a Minute or 2 I would check my Router again and see what new if any IP has been added to my Network.
Then before anything if it is a IP camera and NOT a Wifi camera I would connect to that camera's IP address, I would then go to Setup, Network, Tcp/IP and change the info from DHCP to Static, Then add in my IP, Gateway, Subnet to match my current network or the network I am going to connect this to. I would then apply/save and it will tell you that the system will Reboot and it should after a little time Refresh with the New IP in the address bar. I would log in again on the new IP and make any changes to the admin password if it was an older system that don't prompt you to do so when you first log in...
pscarbor
Post by pscarbor »
Thanks James. I think I got about 10% of that.
First, the camera is not wifi, it is a POE camera. Next, I suppose I wasn't clear about this: I CANNOT connect to the camera using anything: None of the Amcrest apps nor Chrome, Netscape, or Firefox. I can ping the 192.168.1.108 address and I get a return but that's it. Nothing shows up on the router at all, but neither do the other three cameras (one wifi, the other two wired). Since my router only shows DHCP connections this isn't surprising.
There is no way to do a hardware reset, as stated above, and so the 192.168.1 subnet is essentially stuck in the camera and cannot be removed by anything on my network.
What I have is a a single 2.4 GHZ router and a couple of switches. All are on 192.168.0 subnet; I don't bridge or do anything exceptionally weird network wise. So this should be a really simple setup.
After further thought I think the camera was essentially a brick when it came up on 192.168.1 subnet in the first place. You probably hit on the reason: Somebody most likely set it up on a 192.168.1 subnet to test or whatever and now its stuck there. If the next camera comes up on the 192.168.1 subnet I'll just return it straight away, as it seems that there will be no way to configure it. A shame, once configured these are really nice cameras.
It is ok.. Sorry the camera was broke.. I wish I would have been able to have my hands at it I would have been able to get it setup and working for you on your range of IPs...
Sorry I know your Camera was an IP camera but I didn't want to say do this and have someone that had a Wifi camera trying to do the same to get no results so I was just making sure I was CLEAR....
So I will break this down for you make it VERY EASY
Right Click the Windows Button (Normally the bottom left corner of any windows machine) then pick Network
Connections (On Win10 Machine)
Click Ethernet on the left, the on the right click on Change adaptor options, then a window will come up Right click on the Ethernet scroll down to Properties, then click on INternet Protocol Version 4 then Properties, Down at the bottom just above Ok an Cancel is Advanced click it, IP settings will pop up there will be IP setting window where you can click an add button click on add, then inter the ip in the same range as the camera 192.168.1.110 or what ever you want you last number to be that isn't 108, 1 or 254, 255.... Subnet 255.255.255.0 click on save..
Now before you click on advance above if you don't have a Static IP on the screen where you would pick Advanced it will be setup for either a DHCP or Static (Obtain or Use you want to use) then put in your normal IP in this box area 192.168.0.110 lets say (However please note that your router may not have full range IP so make sure that it is in your pool of IP that you router will work some only will work from 2 to 99 and some will work from 2 to 253 so then put in your IP ability) Subnet 255.255.255.0 and gateway 192.168.0.1 if that is your normal Gateway IP and save for your IP to always be used as what you input...
So NOTE Why I mention about your Router you said only shows what is in DHCP and maybe has a limited pool of IP.. However it can or at least my system lets me work on any IP that I have range to connect in.. Maybe it didn't work do to limited IP range ability? Anyway I made a Small Video and connected one of my cameras that I had installed but don't want to show the location of camera so I moved to to my Control room for a video this camera is on a different range of IP and then I connected to my NVR that is on my normal range...
In the video you can see that I have my Normal NVR connected to 10.0.0.222 and one of my IP cameras set to 10.1.23.225 or something I can't remember right now lol as I always look up that setup of cameras on a IP Config Software or just use my NVR for viewing (Different NVR) anyway that can be seen here
http://youtu.be/zb-s95tvaOc
