IP address keep changing to 192.168.0.108
JJB
Post by JJB »
:oops: I have 12 841 IP cameras. All of them are set to static IP with the ending of the IP address starting at 201,202,203,204 etc...
In my ASUS AC 5300 router I have a DHCP reservations for all 12 cameras corresponding with 201,202,203,204 etc....
And 50% of the time they will have their correct address on my network traffic however the remaining times all of the cameras in my router show the exact same IP address of 192.168.0.108 how can 12 cameras all have the same IP address and where did this come from ?
Given time 50% of them will resort back to their static IP or the DHCP reservation.
I contacted the router manufacture about this and brought to my attention that no other devices out of my 60 devices are doing this just the IP Amcrest cameras so through default it has to be an amcrest camera defect issue.
WTF ! Help
JJB
Re: IP address keep changing to 192.168.0.108
Post by JJB »
HELP!!!!!! :roll:
JJB
Post by JJB »
wow this sucks
Melvin
Post by Melvin »
Hello JJB ,
Apologize for the delayed response. So the cameras stop working when this happens? The issue appears strange. Make sure the desired IP's are set as static on the camera settings. Under setup > Network > TCP IP, you can select the right adapter and set the desired ip (If the camera is wireless , make sure the wireless adapter is selected from drop down before setting the IP).
Please check this and see if this fixes the issue.
