Forgot my Cameras Password
ishayco
Post by ishayco »
Hi,
I changed my network to a mesh recently and my cameras got a new IP.
I have four ultraHD 4K POE Turret cameras and I tried to set them up in the app but I cant remember the password.
How do I recover it?
If the only option is a factory reset can you please tell me where the reset button is located?
Thanks!
Re: Forgot my Cameras Password
Will need to know the Model of your POE Camea as some have reset buttons and some need a Shorting of 2 solder pads. However some might have an area on the camera body where you can remove a Door to install a MicroSd card if that is the case then your button would be in there more cases then not..
ishayco
Post by ishayco »
Revo2Maxx wrote: Thu Aug 25, 2022 4:19 pm Hello and Welcome to the Forum.
Thanks for the quick answer!
The model is IP8M-T2599EW.
Yeah camera has a Reset button VIA hatch.
https://support.amcrest.com/hc/en-us/ar ... to%20reset.
Hope that helps
ishayco
Post by ishayco »
Revo2Maxx wrote: Thu Aug 25, 2022 5:06 pm Yeah camera has a Reset button VIA hatch.
Hope that helps
Thanks 😊
You're Welcome
