Hi everyone. Purchased the ASH47-w camera that has a Pan / Tilt feature. I have setup detection zones etc however I noticed that when my wife views the camera and deicides to pan or tilt or both, the camera is not in the correct spot that I had placed my detection zones on originally
Is there a way / feature where after moving the camera around that you can automatically send the camera back to its "home position" (not sure if that is the correct term for what I am trying to accomplish) so that the detection zones I have set up function properly and that the camera is set to view the original area that it was set up to do
thank-you
ASH47-W - Can you set a "home" position
Re: ASH47-W - Can you set a "home" position
No, Unlike a Pro Series PTZ camera there is no Home Position feature in the ASH47, Now there are things that someone can do if they have a NVR or if they have Blue Iris active with the camera. inside the camera however no there is no feature to return to a Home aka Guard Position..
So here is something you might want to think about. Maybe the fastest option without what was offered and that is use ASP with the ASH-47 to setup a preset to the area you want your camera to always face. This way when your wife is done she could just have it go back to that preset and all is golden..
Outside of that the Camera would need a Preset setup for NVR and Blue Iris anyway so for other options that one might be able to setup with Scripts..
