Amcrest with Synology NAS
newmanr
Post by newmanr »
I am trying to configure my 2 cameras with my Synology Has and am having an issue.
The 2 cameras are setup on NOIP DNS on separate ports.
When i add the first camera on port 8080 the test connection is all fine and camera is added all ok. When i try to add the second camera on port 8081 the test connection displays correctly but when i hit save it begins recording the image for the camera on port 8080 so i have 2 cameras set up but both showing the same image.
Does anyone know what i'm doing wrong?
Cheers
markcm
Re: Amcrest with Synology NAS
Post by markcm »
Do you have static IP's set up on your cameras?
I just added my IP2m cameras by using their IP in my synology and it worked great. My synology in stock condition creates all the portals needed to view from outside the home network as well so no DNS configuration was needed
