Amcrest PorHD IP2M-841 - Using Multiple IP address
shward1
Post by shward1 »
Is there a way to disable one of network interfaces so each camera doesn't eat up two IP addresses?
I use either Wifi or wired, but not both. I don't want to have to dedicate two IP address on my network to each camera.
lmm
Re: Amcrest PorHD IP2M-841 - Using Multiple IP address
Post by lmm »
if i understand what you are asking ... are you using both an ethernet cable and wifi?? if so, disconnect the cable or turn off wifi.
What 2 ports are being used?
Albert
Post by Albert »
Hi there,
The router do assigns two IP address to wired and wireless setup. One thing you can do is make the wireless as default from the network settings and delete the wired IP address leased by going to router's DHCP settings.
Thank you
