Amcrest IP Camera Night Vision Not Working
vinayakrao09
Post by vinayakrao09 »
Camera night vision suddently stopped working one day. We have been using this since 3-4 years now. Looks like the red IR lights have stopped working, and a hard reset didn't help. Any suggestions will be greatly appreciated.
Re: Amcrest IP Camera Night Vision Not Working
Sadly it sounds like you have a IR that has either became Disconnected after a Cleaning.. If you don't clean and add new Silica Gel then the next issue isn't going to be as easy unless you know Electronics Background.. That is either a IR has burned out and the way the IR plate was made has taken out the rest or it could be that the LDR has gone out or one of the Electronic components has expired. Apart form just coming unplugged there will need to be some testing and repairs made or buy another camera to replace seeing the Price of a good IR Blaster could cost more then a replacement camera... However there is a lot of Options if one don't want a Quality IR blaster...
3 to 4 years of constant use of the IR it might be a good time to replace the IR as they start to go weak as they age..
