Remove camera views
SirDester
Remove camera views
Post by SirDester »
Hello,
I recentry bought 2 Amcrest IP2M-841B-V3 cameras and configured them in Amcrest View Pro mobile app.
Testing the various options inside app I selected the "4 camera view" and the 2 cameras now displays in a 2x2 grid, top line.
Is there a way to return to a "2 camera view" or manually remove exceding views ? I can't find anywhere in the app and online manual how to do this.
The reason is that, as I only have 2 cameras, in full screen mode sliding from right to left the empty slots are not skipped and they are shows as empty with the "+" button in center to add a camera to the view.
Thanks in advance.
Re: Remove camera views
At the top of the app on the left side is 3 bars with 3 dots click that, Then click Live View it will choose the first camera in list and you will be back on 1 at a time with no extra empty windows unless your using a not full DVR/NVR and didn't only list the ones filled. Meaning if you had a 8ch recorder only 6cameras, if you don't choose the 6 you have then there will be all 8 with 2 empty boxes..
If you have 2 cameras or 2 anything and want to see them it is best not to use Grid view unless you are going to use WebUI on a computer the phones are really to small to get a good look at any detail in grid view.
So by clicking the 2 cameras you have from list on the right top side and live view that it will move both to a single view then drag from right to left or left to right to view them
SirDester
Post by SirDester »
Hello, I thought I answered thanking for the advice but I didn't :)
Thanks !
