Amcrest View Pro on PC and Accessing Remote NVR
dlhigginstx
Post by dlhigginstx »
I need to know if it is possible to use Amcrest View Pro on a PC to be able to access and NVR on a remote network? It is working perfectly via iOS and Android, but would be very helpful to view recordings on large monitor on PC. Thank you.
Re: Amcrest View Pro on PC and Accessing Remote NVR
You will want to DL the ASP program for your PC. You can use P2P to connect to the devices remotely and even have access to the devices WebUI using ASP.
When you are setting up a Device, there will be area for Name, IP address that Ip address area has a Drop down and you will want to choose SN. Then enter the SN of the Device user and password and add it. Once added you can watch from the Desktop window in Single view or even view multi view like you would a normal DVR/NVR...
dlhigginstx
Revo2Maxx wrote: Tue Aug 01, 2023 1:50 pm Hello and Welcome to the Forum.
I'm sorry to be a dummy, but what do you mean by "DL" and "ASP"?
Pogo
Post by Pogo »
"DownLoad Amcrest Surveillance Pro"
https://support.amcrest.com/hc/en-us/ar ... llance-Pro
Here you go https://support.amcrest.com/hc/en-us/ca ... -Downloads
Screenshot (4700).png (577.62 KiB) Viewed 6256 times
dlhigginstx
Thank you.
